compressor
knoxbrendon@yahoo.com's avatar
compressor
mitsu94's avatar
mitsu94
does anyone know if i can use a stock a/c compressor on my mighty max to fill my air tank wiyh a 200 psi pressure switch thanks 4 any help u can give me
TukinRange
yeah i use my stock a/c compressor in my ranger, just be sure to run an oiler in front of it with 30wt non detergent oil and an oil/water seperator on the low side (which is the side that will push air and put a check valve after that. Plus run metal hard lines for about 2 feet because of the heat.
TukinRange
oh i forgot, the r134 compressors can push in upwards of 300psi, but the r12 compressors i'd keep at 150psi. But i only run my 134 compressor at 150.
mitsu94's avatar
mitsu94
thaks 4 the info bro
