20x10s..with 4in BS??
tofnlows10@hotmail.com's avatar
tofnlows10's avatar
tofnlows10
would u have to shorten ur rear end to run these on a 97' s10?? (if so..how much?)
baggedK's avatar
baggedK
YES
Shortened 1.75" per side.
IMLOWER's avatar
IMLOWER
yes needs to be shorted 2" on each side 20x10's need a 6" back spacing to fita stock or bagged s10
baggedK's avatar
baggedK
Yep... 1.75" per side if bagged up to 285 tire and 2" per side if body dropped up to 285 tire.
A 295/25 or 295/30 can fit- but is pretty tight.
baggedK's avatar
baggedK
However you're asking about 20's.... so your options are 275/30/20, 285/30/20, and 275/35/20 which all will work with the provided info.
tofnlows10's avatar
tofnlows10
what tires would everyone recommed w/ a 22x10?? would 255.30 fit?
baggedK's avatar
baggedK
22x10" billet? Hell-no, 285 or 295 is perfect for the application.
Consider a 255/30/22 on a 22x10" wheel. A 10" wheel has an actual 11" section width, and a 255 tire is 10.03" wide. I cannot stand when a wheel is wider than it's tire.
295/25/22, 285/30/22, or 295/30/22 are best suited for the 22x10" wheels on the rear of an S10.
Pirelli makes a matching 245/30/22 for the front 22x8.5" wheels or 245/30/20 if you plan to run 20's. The 245/30 is a match (sidewall height) for the 295/25.
