S10 spindles/brakes on 63 Chevy.
dooredZoo
Anyone know if a S-10 spindle will bolt up on a 63 impala/belair/biscayne? Lots of parts from a S10 are interchangable with the Biscayne, but I would like to know for sure if they bolt up before I order some S10 drop spindles. Also anyone know anything about putting the master cylinder/booster/disc brakes from the S10 on the Biscayne? Sounds simple in theory.
DawgsledMazda's avatar
DawgsledMazda
if the lower balljoint isnt compatible you have a couple options.
1. get custom arms made for bags for the car that have balljoint mounts for the S-10.
2. get a press in sleeve for the S-10 balljoints and weld it into the car lower arms.
plus the upper balljoint holes should be the same as any other GM car, a small 4 bolt pattern so the S-10 balljoints should bolt right in.
the tie rod ends is a tossup. but those can be drilled if they need to be or the tie rod ends can be swappwed for some that fit the spindles and the drag link for the car.
its not impossible, just finding the right parts.
