NEED CONTROL ARMS TO LAY OUT???
24 following
Limitless706 avatar
Limitless706
i was wondering to lay frame on 20x7.5's if i would need control arms?...And if so uppers and lowers? i've heard that you can on factory but then some people say I cant...
S DULLIE avatar
S DULLIE
what kind of ride u got
bdroppeddak avatar
bdroppeddak
depends on what vehicle, the 02 vw beetles lay out on 20s without control arms.
myturn avatar
myturn
www.kustomfab.com
731 536 5252
S DULLIE avatar
S DULLIE
u got a s-10. the easy way is to buy a set of a-arms. if u use the factorys, u have to raise the ball joints up on the top and the bottoms a-arm.
sadexcuse4s10 avatar
sadexcuse4s10
I modified my stock arms to lay on 20's
and no you don't have to raise the balljoints on an s-10, you simply cut the humps off the lower arm and plate it, and angle the upper balljoint in about 13 degrees and reweld the arm at the new angle
then you just trim down your bag cups and notch for the tierods and notch the lower arm mounts
don't forget to tub the firewall, and raise the wiring harness, and rebuild your blower box to clear your tires
it's a weekend job if you have some good welding skills and some sheetmetal and 1/8" plate laying around
bdroppeddak avatar
bdroppeddak
hey kustomfab any word on those fullsize chevy balljoint rings for the lowers?
myturn avatar
myturn
YEAH - I PICKED UP ANPTHER DOZEN OF THEM FROM THE MACHINE SHOP TODAY - CALL THE SHOP TOMMORROW IF YOU WANT SOME
bdroppeddak avatar
bdroppeddak
heck yes i do.
Limitless706 avatar
Limitless706
