Looking for a good but cheap Pinstriping kit
brandon005 avatar
brandon005
I know very little about pinstriping and want to get a set to try it out but I don't want to spend a lot of money on something I may not stay with. I'm really not looking to spend more than $50 or so, also what kind of paint do you use when striping? I have heard good things about 1shot.
brandon005 avatar
brandon005
DougyFrisch avatar
DougyFrisch
perfect, just what ur needing to get started
just get some cleaning supply's, reducer, and an old magazine and ur should be ready to roll...
dragn168 avatar
dragn168
thats where i got my brushes from i think i paid 40 bucks for all the mack series 20 brushes also check out www.pinstripersdepot.com they sell 1 shot kits with 8 cans up to the full line of paints and just about every thing you need for pinstriping
brandon005 avatar
brandon005
why an old magazine? also I'm thinking of practicing on printer paper is this thick enough? or do I need some special paper to practice?
david49910 avatar
david49910
you use the glossy magazine pages to thin out the paint and i would recommend practicing on glass. when youre finished and the paints dry, you can just scrape it off with a razor blade.
brandon005 avatar
brandon005
thanks for the good ideas also how do you clean the brushes? do you use a reducer? also should the 1shot paints be thinned or do you use them straight out of the can?
Pecker avatar
Pecker
You're on the right track, except, you said"you might not stay w/ it gotta feel the love...even when you get pissed at first.... one shot is good to work with. Use a med. to slow reducer, (in a seperate cup, to wet the brush)...Don't try to clear over it, though. It'll wrinkle. Glossy magazines don't absorb the solvents as quickly. so that's why they're nice. mineral solvents, clean up "junk enamels" easily. AND. When yer done. Use a "Brush conditioner" (or even a drop of tranny fluid) to work into the brush...to make it last. P.S. Pick up one of the "how to" books at your local bookstore. P.P.S. STICK WITH IT!
Low_SST avatar
Low_SST
if you go on ebay you can get a 5 pack of 1shot for 25 and then get some mack 00 brushes and any other reducers you may need and you would be spending about 40 total.
