spacing bed back up
spacing bed back up
lownism0
I raised my bedfloor 4" what is everyone using to space it back up so that it lines up with the cab, and does anyone know of an online website to buy bolts from. I went and tried to buy some bolts that are 4" longer than my stock bed bolts and they were $6 apiece and I'm going to need 8.
taco2nv's avatar
taco2nv
Basicly i just cut some round tubeing then used washers to line it up perfectly. your going to need weld 4 nuts under bed were the mounts are located... then use tube and washer to shim it up and bolt it in and your set.
dawgpimp's avatar
dawgpimp
Edited: 1/22/2006 2:24:48 PM by DAWGPIMP
this is what i did.....
rangerrudy's avatar
rangerrudy
I used plastic body lift blocks and cut them down to the correct height!
lownism0
where did you get your bodylift blocks at?
GMCTRUCKS
i just used 2x3 box and cut a small section of it for the spacer and drilled a hole in the top of it so i could still use the origional bed bolts. i also had to use a couple washers to get it just right
JETSETTER's avatar
JETSETTER
I used ALL THREAD from the local Home Depot and threaded it into the bed and tacked it, then used thickwall round pvc pipe cut to length for spacers then washers and nuts, works well. I used metal pipe first and the bed squeeked. This works well for me!
