BAttery keeps diein.
canadian4_life2003@yahoo.com's avatar
86nissan720's avatar
86nissan720
OK its a nissan 720 and theres no lights on that i know of but my battery will die after 2 days. i have a new alternator and battery. Has anyone had a problem with this after they bagged a truck?
LowRangerMS
Do you have any stereo amps hooked up? Or do you have any Hot wires that are NOT connected to anything, but are still hooked to the battery?
My x-g/f went through 3 batteries before we relized it was the 4gauge hot wire we unhooked from the amp but left connected to the battery. After we disconnected it from the battery, never had another problem.
Good luck with it man!
impulse's avatar
impulse
thats probably the problem im having with mine... thanks dude!
86nissan720
There isnt a stereo hooked up anymore and all the wires for that were discounected.. But i think there is hot wires that arnt connected to anything that we cut when taking other stuff off. What could i do to stop that will out takin the wires out? anything?
gtphelps
there's tons of things in the car that could be your amp draw. I have seen dome lights kill batteries. It did on mine. I had my door skins off and the pin to shut off the light wasn't being pushed in, which left the light on. But my truck sits for months at a time. DAMN WINTER!!
kaoss's avatar
kaoss
Edited: 1/21/2006 7:08:10 PM by KAOSS
do you have a volt meter?If so do this...Take your negative battery terminal off.Hook the positive side of the voltmeter to the negative side of the battery and the negative side to the voltmeter to the battery terminal you just took off.THe volt meter should read something.pull fuses out, one at a time until the volt reader reads nothing. the fuse you pulled out that made the volt meter read 0 is were the problem is. (by the way, my wife says you misspelled dying.She also says we're minitruckers and don't have to be smart.)
kaoss's avatar
kaoss
sorry make sure the key is off
86nissan720
lol thnk ill try that
L T's avatar
L T
werd, and make sure you pull the dome light fuse right away or make sure the doors are closed, you can do this with a standard test light too, or shit, any 12volt light bulb will also work.
