just baggin the rear..
Drgnbxchvy avatar
Drgnbxchvy
all i want to do is bag the rear of my blazer... i am thinking of all 3/8" stuff and a 7 gallon tank... but i am not sure of what compressor to run and bags...
Drgnbxchvy avatar
Drgnbxchvy
i am thinking of run a 4-link too just haven't found one in my price range and style i want... also not sure if i want to mount the bags on the axle or behind it or something else.. i am trying to keep the price low with blowing a lot of money because i am getting married
Drgnbxchvy avatar
Drgnbxchvy
anyone i know some people are on... you guys don't have any ideas
low mazda avatar
low mazda
go through www.gravity-werx.com
and if your not gonna get an engine driven comp. go with an air-zenith...
Drgnbxchvy avatar
Drgnbxchvy
what about a 4-link... does anyone make a blazer kit ...
bill brasky avatar
bill brasky
why not bag the front 2
AVTekk avatar
AVTekk
what year blazer is it? is it 83-94, 2wd and 2 door? if so, Larry at InnovativeAirSuspension.com makes a kit for it, that will be the easiest way to go. otherwise everything will need to be custom, no one else makes anything for blazers yet.
whynotfab avatar
whynotfab
an air zenith compressor would be perfect on a 7 gallon tank.. check around for everyones reviews on those, you'd probably be happy with one. Bags would be just kind of a personal preference thing in most cases.. you mentioned 3/8" valves so you probably aren't going for extremely high psi/speed.. Firestone/Contitech are around the same price, Slams a little higher but could ride better/handle higher pressure depending on how you set it all up. After doin all of the rear, having air management hooked up.. itll be nice to just take a day or so and bag the front very easily in the future also
Drgnbxchvy avatar
Drgnbxchvy
its a 91 blazer 2wd 4 door... i have bagged a s-10 before ... i just don't care for the front the ride is killer with just the rear it rides 10 times better ... yes doing the front is easy but this will be a daily beater and has to ride nice cause of my girl.. also don't want a lot on money in to it... going to go with a 5" drop in the front
Drgnbxchvy avatar
Drgnbxchvy
InnovativeAirSuspension.com has some great stuff but their blazer kit is for 2wd and 2door not a 4 door ...
