im currently in the process of bagging my 95 s-10 i have 20" wheels which im trying to tuck.but i have to cut the fenders out and there are wire all on my driver side by the fender. some i know are headlight some i know are air bag. but what i dont know is the rest and what should i do whith them, or where should i relocate them , or do i even need them.
johnz
you need them youll have to relocate them..more then likely extend them find a clean place to move them
minipu95
does any one know where i should relocate them.
also what bout the wires that run into the cab.
Low_SST
i would relocate them away from the tire. and moving parts.
W
wizard8575
Edited: 1/18/2006 9:31:37 PM by wizard8575
Ok well first off if you dont know already in order to tuck 20s even without a body drop you will need to tub your firewall and possibly replace brake booster. You will also need to mod the arms or replace them. with that asside there are 2 differnt ways s10s had their harnesses 1. the computer was under the hood 2. It is under the dash. Either way the harness has to move. If it is under you dash the passenger side harness should be fine may need to move it up some. On the driver side cut out the hole the harness goes throught and move it up higher on the firewall I have seen some go in though under the cowl so it will actually go down into the cab. Good luck I started to run the harness for my 6 cyl and thats why I have a 350 now.
