turbo starion motor or 4.3 bowtie?
jpacker72@gmail.com's avatar
FluffyFreak's avatar
FluffyFreak
whats up? i gotta 89 mighty max and im debating between a turbo Starion motor or a hopped up 4.3 V-6 bowtie with a 350 tranny . any suggestions? how about where to get motor mounts for the 4.3 if i go that route?
cookiemonster13's avatar
cookiemonster13
i would personally go with the turbo motor
Low_SST's avatar
Low_SST
starion motor or the conquest tsi bolt up nicely because there based on the 2.6l block. if you go to 4x4wire they have a section on mitsubishi trucks and there are a few guys there with that swap.
BAGGED 68 FORD's avatar
BAGGED 68 FORD
Turbo motor all the way.
shvd64cdy's avatar
shvd64cdy
small block chevy 350 (yeah, i know it wasn't an option, but it's hard to beat 40+ years of performance from those engines, plus parts are readily available and it really isn't much larger than the 4.3 you're debating).
F
fatnutz69
lots of people on here have mounts for the 4.3. i have two sets right now. i dont know about the turbo motor other than i want one. sams got a point though. also parts are cheaper for the small block than they are for the 4.3. probably more redilly available and cheaper than the other motor you are talking about. it also bolts to the th-350 trans also. good luck beau
N
nrre
id have to go with the 350 as well even though it wasn't an option...
or a poncho 400
xflowgolf's avatar
xflowgolf
rock the turbo motor
