Z'ing frame 98-00 rangers HELP
prize possessions avatar
prize possessions
Hey , Im starting to Z the frame on my 2000 ranger, i got 2 very qualified guys helping me , one runs a custom suspension/fabing shop here, anyways we havent realyl talked about it too much and im jsut wonderign who on here has don it and can give me some tips or tricks and letme knwo exactly what is involved and ur methods of doign this job thansk alot for the help
DawgsledMazda avatar
DawgsledMazda
I found that 2.5 inches is the right amount. we also raised all the control arm mounts. we sectioned the engine crossmember and that helped about another inch or so.
BUILTON24S avatar
BUILTON24S
i did one about 2-3 years ago and was about 2" or so.very straight forward and easy just remove the fuel/brake lines on the inside of the rail
prize possessions
hey guys , with raising the frame and motor up doesnt that put the engine on to much of a angle with the tranny
hotrodcarey avatar
hotrodcarey
yeah but its not really enough to effect anything. my frame is zed and i should be driving it tomorrow or so.
msturg avatar
msturg
Michael White, do you know where you had to notch the floor, how much did you have to raise it up. I keep thinking about doing this but I really don't want to lose my center console. with fuel brake lines do you have to simply bend the factory ones some more or do you have to replace them completely, also how far back would you have to replace them.
time1 avatar
time1
i did a 1 inch Z on my toyota and it wasnt hard at all. I did have my motor out when i did it so that made it easier. I just did a little bit of bending with my fuel/brake lines and they went back together. If your motor is still in i think the only problem your gonna have is welding the inside of the framerails after the Z. If you got any questions hit me up!
DawgsledMazda
we did the frame Z up 2&1/2" on one truck and 2" on the other. both had room for the trans where the shifter boot comes thru.
but behind the trans the floor had to be cut for the driveshaft. hit me up for pics
barnyard-customs@sbcglobal.net
