need serious help
bubbagreenfield@hotmail.com's avatar
need serious help
synchrocustoms's avatar
synchrocustoms
i'm suiciding some doors at my shop and i'm stuck...when i open the door it woin't go all the way open and i was wanting to know if i moved it in or out would that help me in my problem...
Low_SST's avatar
Low_SST
is the door hitting something or is the hinge binding?
synchrocustoms
no..its not binding...the back of the door hits the quarter panel about half way of opening...i was wandering if i moved the hinge in or out in the jamb area if that would help..just wanted someone's help that might have done some b4...
cookiemonster13's avatar
cookiemonster13
are you using factory hinges or what? what kind of car or truck. i would assume car since you said quarter panel
synchrocustoms
its a 96 nissan sentra..i'm using hinges from airbagit.com
TC29720
^^^ theres your first problem. You're probably going to need to move the door forward bit. Can you provide any pics?
Low_SST's avatar
Low_SST
you are so blaufucked.
your hinges are too far away from the outter skin
there a shitty brand
and im assuming this is a customers car and this is your first time.
1fastlx
the hinges need to be closer to the door skin and it will change the swing of the door
