To cut,weld or bolt on that is the ?
xtrememedic avatar
xtrememedic
I want to bag my truck but dont really want to cut or weld on my truck. I have seen bolt on units what r the best and who do I contact. I own a 2000 s-dime xtreme. Happy New Year and thanks for the help. Jerry
bagged89S10 avatar
bagged89S10
You still have to cut some with the bolt on kits. I sell some nice KP Components products that you might be interested in. Just email me or IM me.
BodyDragginGMC avatar
BodyDragginGMC
It's going to be hard to bag it without cutting or welding. You would deffinately have to cut the frame. You also will have to trim out the front spring pockets for the bags.
frshryd avatar
frshryd
you can bolt on your cross memers / bag mounts...trailing arm...ummm lots of stuff, but you will need to cut your frame rails for your step notch, for clearance gor your rear axle.
slamdamazda avatar
slamdamazda
If you just want to bolt stuff on buy a civic and go to autozone.eeek....did i say that?
kindalow avatar
kindalow
There are kits out there that you dont need to cut the rear frame on, it wont lay out and most people on this site dont think there is a point to bagging it if it doesnt lay out, but its your truck.
suckafree avatar
suckafree
I only suggest welding if you are capable of metal fabrication and your welding skills are up to par. And like someone said you absolutely have to cut to be bagged. You need to cut the spring pocket so the bag doesnt rub. And in the back you could get away with bolting in a roadbater or whatever they are...but you still have to cut the frame for axle clearance.Good Luck and keep us updated
wizard8575 avatar
wizard8575
www.airliftcompany.com makes bolt on kits all you need to do is drill holes for the gen 1 kit but it doesnt lay completely, the gen 2 lays but you have to cut for that one.
Ih8bmps avatar
Ih8bmps
Air ride technologies has the road grater and front cups and also shock relocate all bolt in,with little cutting...Hit me up I sell all the best goodies...
guiltybydesign avatar
guiltybydesign
This is like saying "I want to play sports, but i dont want to run or jump or sweat. Is there a way around this?"
