whats up anyone know of a company that might make a tank small enough for a bike
ashvdbx
any help will be apr.
DOWNSUB
AIR TANK I GUESS?
ashvdbx
ya air tank sorry im still hungover lol.
DOWNSUB
I would just make one out of round pipe and cap the ends.? cheep
Blazinlow15
Suicidedoors.com will make u a tank anysize u want...
BodyDragginGMC
make the frame the tank
LowOrange88
I was going to put a cylinder on a minichopper, and I planned on using a CO2 cylinder from a paintball gun. Small, compact, and will hold all your air and they come in different sizes. Just food for thought.
ashvdbx
thats a good one .. i might try that but only one way in for air what about out?? t with a check valve maybe??
TwistedMinis
I'm working on a full air ride mini right now. Still looking for small air struts, but I've got the tank done. It's two parts. One portion of the tank is a dummy oil pan, and I put my oil pump in a billet cover by the end fo the tranny. The other portion of the air tank, it underneath the tranny, motor, and doesn't hang below the frame. It wraps up onder the lower rails, and caps off the downtubes. Both portions are linked together, and made of 1/8" plate TIG welded together. We had them at 180 PSI with no leaks. I'd like to run 1/2" valves, and I'm guessing I'll be able to get 12 full lifts with the air capacity I have.
Low_SST
firestone sells half gallon tanks. check out some of the air horn tanks.
