autoloc ppp35k help asap!!
skirtin99@yahoo.com's avatar
lownoma99's avatar
lownoma99
wires are all hooked up from solonoids to brain do i need to use the (yellow/black) key on acc? where do all the channel wires go to? all im trying to do is open the f*&$king doors!
str8down's avatar
str8down
no help? anyone!
sukntire
READ THE DAMN DIRECTIONS YOU FREAKIN MORON.
SSM-Webmaster's avatar
SSM-Webmaster
I didn't hook up the key on acc on mine, I'm pretty sure that is so it won't let you open the doors while the engine is running.
railin93's avatar
railin93
yeeeeahhhh....you probably don't wanna do that anyway...i always leave the acc wire unhooked so the doors doon't get locked/closed shut when the ign. is on...autoloc/vpa/whoever is not the greatest companies for shaved door kits anyway...next time if you get the chance (pretty sure you will soon since it's the autoloc kit) buy a SPAL kit...doesn't cost as much and comes with everything already hooked up except the door wires and the power and ground!
str8down's avatar
str8down
bump
ShakinPlates's avatar
ShakinPlates
channel wires? just read the paperwork man... you will eventually get it
