plastic fuel cell question...
phil@lowdowncustom.com's avatar
balcar's avatar
balcar
I have a used plastic fuel cell, and due to the weather and such it has sunk in the middle. Is there anyway to bring them to the original size?
SSM-Webmaster's avatar
SSM-Webmaster
did it sink because of the change in air pressure from temperature drop?
I would take it out, drain it, seal everything back up except for one port, and hook it up to compressed air and force it back into shape, the ones I had used NPT thread, good luck hope this helps
Low_SST's avatar
Low_SST
where is your return line coming in? that can cause it to do that.
badfish57's avatar
badfish57
cold weather most likely caused it.. it might pop back out when it gets warmer out .. or you could do like i would and just fill it half full of gass and toss the hole damn thing in the fire.. no more worries.. except for the 2nd and 3rd degree burns
bigjon's avatar
bigjon
same thing happened to me and i tried to blow it back up with air and just went back to suck in i guess its just will be like that. next time i will get aluminum.
toreadorxlt
mine did it too. piece of shit.
Severed701's avatar
Severed701
yeah i think they all do that
bodydropped85's avatar
bodydropped85
get a metal one, plastic ones SUCK.
