Question about size of ragtop in x-cab s10
gbd4life
I'm wanting to put a ragtop in my 94 s10 and I'm wanting to put the biggest I can with out hardcore cutting into the sub-structure. If you have one let me know the size/brand/and some of the difficulties you ran into. Thanks for the help
krayla
Measure your roof and see what fits. depending on how big you want it to be check and see the sizes and compare to what you think would look best.
Deflaytedwayz1's avatar
Deflaytedwayz1
i'm not really sure on my size i think it's 35x30 but it might be 35x40. anyways it runs from about 1/4" - 1/2" from the third brakelight to the beginning of the windshield slope. i got mine back in 2002 from streetbeat. just called them up and asked what was the biggest to fit in an s10 $500 dollars later i had a big ass hole in my roof. it's electric and i believe made by inalfa. the only trouble i had was the support beam that runs by the b-pilar. once you get the framing in for the top it gives it most of that structure back. just make sure you measure and remeasure to make it square with the template. mine leaks a little cause the locks that pull it tight when closed aren't functioning properly but it's not that bad. overall i like it, plus there aren't any other one's around here and people kinda trip about it.
Deflaytedwayz1
Deflaytedwayz1
FATSHI's avatar
FATSHI
YOU CAN PUT A 35x40 IN EXTRA CAB S-10 AND IT WILL FIT FINE. I WENT A LITTLE SMALLER WITH A 35x35.
str8down's avatar
str8down
I put a 35x35 in my o1 and it fits nicely, if you go bigger you have to make relief cuts in the frame of the rag top! no big deal just whatever you feel is the best.
