AC compressor
AC compressor
TSlow4x4 avatar
TSlow4x4
Hey Guys
I have a 94 4x4 s10 blazer 4 dr that Im in the process of customizing (bagged,shaved everything etc.) What I wanted to know is have any of you out there converted your AC compressor to run air to fill your air tanks and if so is it a hard mod to do?? I would like to do this mod so I have instant air all the time(I have 4 scuba tanks im going to use for air supply)
Thanx for any info Tim
chumpchange avatar
chumpchange
there was a post in under mazdas about two days ago that had pictures and info on doing this. you might check there and see if it helps you.
KANTILEVER avatar
KANTILEVER
I just got a compressor from the junkyard took the stocky out. Bought a clutch and bracket from www.onboardair.com
not sure if this was what you were looking for, but the stock a/c pump on a s-10 will burn out quick. You need a pump that doesn't use freon for lubrication like a york or sanden.
