Dropping my 56 ford
Dropping my 56 ford
xtremeranger avatar
xtremeranger
So I have a 4 door 56 customline, I have some time this weekend. So I figure I might as well lower it finally. I havent seen any bolt in parts for the front I heard they make spindels but have had no luck. So Im just going to vut the coils. I know to trim a little at a time, but what would you advise for about a 3 inch drop? Out back Im going to take out a leaf and use a 3 inch block. Am I going to run into any problems? besides the bump stop maybe? Thanks guys
VICS22 avatar
VICS22
VICS22-UTM
boooghar avatar
boooghar
check with fatman fabrication, im sure they have something for the frontend ... the rear if i remember correctly has 5 leafs, myself I would pull a couple, run a 2 inch block and some air shocks and whack the sheet out of the front coil
TwistedMinis avatar
TwistedMinis
Try Classic Performance Products. They might have what you're looking for.
www.classicperform.com
Low_SST avatar
Low_SST
the best way to drop it is off the back of a flat bed tow truck at my house.
bodydropped85 avatar
bodydropped85
i pulled the 2 shortest leafs on a 51 pickup and it dropped it 2 in...
hopsing avatar
hopsing
He's got a Customline 4 DOOR. Not a truck.
