Starting from Scratch(air ride)
12 following
jbtank85@yahoo.com's avatar
DodgeRT's avatar
DodgeRT
Iam thinking about getting a civic and was wanting to put cans on it,but i want to buy everything at a time instead of all at once(y i don't know)i know the basics like cylinders compressor/s tanks but my only problem is the fittings,like what angles,straights ,tee's,elbows and how many.Ive seen some that are brass and some that are push-n-pull.what size inlet is on the cans? and i'd probally run 1/2 or 3/8" valves with fbss bogleg.
DodgeRT's avatar
DodgeRT
i just read the article on hydraulics!!! what would it take to get hydro's(installing the cylinders on the control arms) and pretty much everything else im a noob to hydrosany help would be appreciated
9
92LOWYOTA
i have heard bad things on putting hydros on unibodies, eventually they will flex and your car will be permantly sitting dogleged.
but never done one so not sure. If u are wanting any hydros or airirde hit up rick at fmkustoms.com he will hook u up
stcaddad's avatar
stcaddad
I like hydros with accumulators on Hondas alot better than air cylinders. I had a civic with juice and a big slider for five years never had any flex problems even three wheeled it all the time. you can get a nice chrome two pump four dump set up with accumulators for well undeder $1500
DodgeRT's avatar
DodgeRT
big slider?? iam new to the juice.lol
DodgeRT's avatar
DodgeRT
so would juice be the way to go??
DodgeRT's avatar
DodgeRT
thanks by the way
maniacalmini's avatar
maniacalmini
slider would be his rag-top. not being a jackass just informing you.
DodgeRT's avatar
DodgeRT
right,i thought it had somein to do with the dro's
CiViS300
Yea if you know someone with fab skills then juice is the way to go, but if your going to be doing this yourself then the bolt on cylinders is a better choice. Hydros will get you a little lower than cylinders will also.
