Ls vtec
chrisdoug
I got a really good deal on this integra but im new at all of this and i was wondering what else i could do to this to make it faster here is what is has already: LS BLOCK B16 HEAD WITH GSR CRANK SHAFT AND TRANNY,JE PISTONS 12.1 COMPRESSION,EAGLE RODS,FUEL RAIL AND REGULATOR EAGLE FUEL INJECTORS,AIR INTAKE,CHROME HEADERS,ACT CLUTCH WITH ALUMINIUM FLYWHEEL.......can i supercharge it? cause i cant turbo it.
thanks any ideas will help
DodgeRT's avatar
DodgeRT
It might blow a piston,with that setup its stricly all motor!!!no superchager for you
H22CRX
why do you think that you can't turbo it? definetly dont supercharge it. you will get going faster if you supercharge it but in the long run your turbo will still be running. ECU is really the only thing i can think of that can make it faster besides turbo.
gtphelps
Probably because he doesn't want to get rid of his Chrome header.
shortyscustoms
bore the block,get it sleeve and add hondata, or a stand along system,nos if not fast enough. vtec controller.loose the ac and powersterring.get some lighter rims.
drvndalycrx
low compression for turbo... high compression for supercharger... supercharge that mofo.. or put a nice n20 shot on it... could handle a 100 shot easily... whoever said its not built for a supercharger is a moron
