layin frame
layin frame
rbwhat377
Hey guys I'm new to the forums. I have a 00 f350 with the 7.3l in it. I am getting ready to bag my truck. I know I need to run a fuel cell so I can lay frame. My question is does anybody make one that the factory sending unit drops into. And if not do I just run a inline pump? What GPH would I need? Any info will greatly help. Thanks.
lockone's avatar
lockone
I think that there is enough room to raise your stock tank up inside the frame enough for clearance.
rbwhat377
K well ill check when I pull the bed off. But if I can't what can I do?
WK
wellbilt kustoms
I would get a fuel cell and mount it in between the rear frame rails behind the axle. It will get your tank situation taken care of, and give you some room to build/put a 4-link kit on.
When I run fuel cells, I like to run electric inline fuel pumps along with fuel filter. If you don't want to spend alot of money, check out summit racing. You can get a decent size fuel cell for a pretty good price, and an electric fuel pump. They also sell complete kits. Fuel cell with sender and pump installed inside the cell already.
It all depends on what you want to do, and what your budget is.
make sure to post up pics when you start installing the air ride.
Good Luck!
