I need opinions...
mtmc85@gmail.com's avatar
I need opinions...
mtm's avatar
mtm
Ok, last semester i had a welding class and did quite a bit of welding. Well, i fell in love with the tig and i'm looking to buy one. I am going to use it for exhaust work because its easy to work with and it leaves seamless beads. My question is, has anyone ever used a 120V Tig machine? The tig i always worked on was 220. I don't have much money to spend on this but i found one for $400 that i might get if its worth it. I've never heard of the brand but here are the specs on it, let me know what you think...
DRAGSTER SPEC SHEET
DRAGSTER 85 Thermal Arc
Tig- Stick Packag
Perfect for light duty stick (SMAW, or CC) welding .
Comes complete with:
TIG Kit: 12.5' Air Cooled TIG Torch w/ valve, accessory kit, 10 ft. gas hose ,regulator, and attached dinse connectors.
25 mm Twist Lock Output Terminals.
Heavy duty 6 gauge 10' Electrode cable and Electrode Holder.
Heavy duty 6 gauge 10 ft. ground cable with rugged clamp.
Thermal overload protection.
Processes: STICK (SMAW) SCRATCH TIG (CC)
Features:
Welds up to 1/8 inch in a single pass. 25mm twist lock output terminals for easy polarity reversal and cable change.
Self-resetting thermal overload.
Convenient on/off switch.
Carrying strap.
Part Number #10-3077A-3
115V, 60 Hz.
Rated Output at 25% Duty Cycle 85 A
Output Range 5-85 amps
Dimensions (H x W x D Net 5.12 x 10.24 x12.60 (in.)
Weight 12.12 lbs.
shvd64cdy's avatar
shvd64cdy
400 bucks? fair price........not great, not bad....but decent price......pick it up and rock it!
scr8per's avatar
scr8per
i took two years of welding at a vo tech i think that welders kinda small but you said you were going to use it to do mufflers thats probably ok 85 amps isn't much but good luck
Snakesunlimited's avatar
Snakesunlimited
Only down side is you don't have a pedal like normal GTAW machines have. So I think once you strike the arc then the only way to adjust it is having a short or a long arc. And the air cooled torch kinda stinks... but 400 bucks you Can't beat it... Check out miller has a comparable welder... similar size and all but I think its more like $1,000 or more if I'm not mistaken...
But like I said 400... that would be nice to have to do little sheetmetal stuff... like blower boxes and whatnot...
