help laying out the front of a 99 dokota
drgnrockr
i got my 99 dokota laying allaround but i need it to go lower in the front i need some pics of the parts that need to be sectioned and need to know if it needs controlarms up front and where to get them this is my first dodge so could use all the help i can get. thanks
jayslowlow's avatar
jayslowlow
cando makes arms they are pretty salty. you can z the front to get it lower. your crossmember hangs 2" lower than the frame. check out www.customdakotas.com
WF
Wicked Fantacies
Jaysons right u r going to have to Z the front to go lower. Depending on what size rim and tire combo ur running will depend if u need new arms. Rakilla layed his 22's on stock a arms but I never seen it running. (Not hating) just saying.
fatheadjames's avatar
fatheadjames
If its not z'ed then you need to do that or rebuild the crossmember somehow. you don't have to get control arms but they make things a little easier. Cando makes them about the only ones I know of. You can narrow the factory ones and build in some drop if you wanted to.
