380 viair compressor barely pumping?
stopndrop
i havea a brand new viair 380 and ive had it on my truck for a couple months and last night it desided not to pump. so i had to drag ass home.ca n anyone tell me wat woulkd be wrong. i really need elp fast cause i dont have any money to get another one right now. any help will be appreciated. thanks!
tmiit71's avatar
tmiit71
assuming your electrical is good, then I'd say the reed valve on the piston probably snapped. again, just a thought. Also, i have an 380C for almost two years, only having check valve issues. i got rebuild kit too from streetnshow, for $35.00. hope this helps.
laydsuzu's avatar
laydsuzu
broken check valve which pumped air back into the head of the comp which blew the comp. viair has been producing defective check valves ALOT lately from all the problems people keep telling me about. I have a 380 but i got it 3+ years ago, and ive had it a long time running with no problems.... tell viair about it and complain, maybe they'll send you another one. unless you wired it up wrong and voided the warranty
bodydropped85's avatar
bodydropped85
sounds like the check valve.
stopndrop
yeah its wired up right. so the comp is fd? ill complain to viair. thanks for the help!
scotto79
just tell them politely and they will be a lot more helpful than if you're a dick about it
FullSizeRST's avatar
FullSizeRST
yea i have two viair 480s and one of the check valves took a crap but i replaced it and its runing like a champ id disconnect the air line and see what she does then with no back pressure and just feel how much its pumping if its pumping fine then its deff. a check valve other than that get two rebuild kits and keep one in ur glove box ........ good luck
SCINFERNL
Was this worked out to your satisfaction?
Please let me know if you need further assistance.
email:
lancem@viaircorp.com
