IIGHT IM GOIN WITH A FRONT BACK SIDE TO SIDE SETUP....and ive been lookin at tanks...how many ports does the tank need to have to acheiv e F.B.S.S??
chevyman992002
i'd have atleast three. One for your compressor to come in the tank. One for a line going to your front valves, and one for a line going to the back. Just about any tank you get though with have atleast 4.
CM
c mau
thats what i thought...wtf are these tanks with lik 8 ports for!!
keele
A tank with 4 should be fine. One with like 8 really isn't needed. You'll end up pluggin some of the holes
keele
some people for some reason will run a seperate line to each corner all the way from the tank. That takes up four then some run two compressors which they put in different holes. And then the others could be used to tie multiple tanks together. But really 4 is ideal
CM
c mau
iight cool thanks
simm1523
how do you get front/back side/side with out running a line/valve combination to each individual bag? maybe one line from the tank that splits into two with valves after the split? just curious...
keele
I ran one line up to my front and one to the back. That then fed into a brass T and split to my fill and dump for both sides
bdroppeddak
hell you only need one port if you wanted, just have to T stuff.......
