Fiberglassing a dash question
famzarate10 avatar
famzarate10
ok guys im going to start on my dash and i want to fiberglass it so whats the best material i need to get? Could u guys make a list of what i need in order to get it fiberglassed.
famzarate10 avatar
famzarate10
anyone?
sickdime94 avatar
sickdime94
ARE YOU GLASSIN THE OLD DASH OR MAKIN A NEW ONE? YOU NEED FIBERGLASS CLOTH , RESIN ,HARDENER,SOME GLOVES ,A WELL VENTILATED AREA AND LOT OF PRAYS CAUSE YOUR GOIN CUSS ALOT ONCE YOU START THAT PROJECT. FIBREGLASS IS A FUCKIN JOB BRO.GOOD LUCK AND LET USE SEE IT
exotic dreams avatar
exotic dreams
i would only fiberglass what you wanted to shave on the dash with fiberglass mat, cloth, and resin. then use duraglass to smooth out. the rest of the dash can be sanded with 80 grit to remove the texture. then just use high build primer over a flex-agent like "Bulldog" adhesion promoter. then just prep and paint
dragggn avatar
dragggn
www.fiberglassforums.combad ass site..look around and you will see some sic set-ups.. apply what you see to your application.............
jdauer02 avatar
jdauer02
check out fiberglassforums.com and check out the dash projects there
dragggn avatar
dragggn
too quick for ya jayme
hahhahahaaaa j/k
famzarate10 avatar
famzarate10
Thanks guys im glassin the old dash larry i want to keep it the same but want it to look smooth.
trashed avatar
trashed
you could always sand the texture off and use a light glazda for any imperfections...
famzarate10 avatar
famzarate10
anyone have any pics? To get an idea of how it will turn out.
