dual Viair 380c's vs Air Zenith
MDcrew208
what do you think... i couldn't really find all the specs on the AZ and the dual 380c deal is lookin pretty good. (the dual viairs are 2.98 cfm at free flow compared to 2.85 for the AZ) also the Air Zenith website says it fills a 5 gallon tank from 0 to 200 psi in 7 minutes... the dual viairs says 7 min and 11 seconds... I just cant find anymore specs than that on the Air Zenith... what do you all think. Thanks
grunion
AZ is my vote.One AZ will draw less amperage and take up less room.
BaggedWagon
viair
Rob Clayhill's avatar
Rob Clayhill
I havent used any Viairs yet but my Airzenith seems to do the job pretty good. everyone thats used viair before has said the AZ does the job of 2 viairs. its not as loud as viairs either supposedly.
thacru78's avatar
thacru78
Two weeks ago I was in your shoes. I couldn't decide if I wanted the Dual Viars or the Air Zenith. I went with the AZ because I didn't want to deal with two compresors when one could do the job for close to the same price. I love the AZ. It fills my 8 gallon tank from 165 to 200 in like a 1.5 minutes. I mounted it strait to the frame, and if the radio is on low you can't even hear it. You can feel a little vibration but not much. It doesn't draw much either, the lights don't even dim. I got my AZ from fmkustoms, with a pressure switch and water trap for $320 shipped. Got to my house 2 days after I ordered it.
bagginitdotcom
Check out the fill time calculator I have here and you can compare fill times if thats what you're interested in at all... http://www.bagginit.com/Miscellaneous
s10
last post by baha +1y
