Specs. on AirTank
MrLarryDouglas@hotmail.com's avatar
Specs. on AirTank
95FullSiZE's avatar
95FullSiZE
Is anyone using this tank? StreetBeat is where im looking to buy it. If so i was wondering if you had the dimensions like, overall height and length. I am wanting to put this between the frame rails on my fullsize. Cant be over 32inches long. Here is the link for it.
http://www.streetbeatcustoms.com/artf9242-sy.html
whynotfab's avatar
whynotfab
I'm not familiar with those, I mainly sell/use the 8 port versions of 5 gallon tanks.. it does look like the Firestone tanks that are a little slimmer though.. in that case, it'd be about 34" long.
I have the dimensions of the tanks I sell posted beside them on my site, sometimes you can just assume the size is close by looking at pics since 5 Gallons are usually in the same area in size, except some are short/fat, some long/slim.. maybe these can help:
http://whynotfab.com/store_tanks.shtml
You could always try calling streetbeat or ART also. Good luck,
95FullSiZE's avatar
95FullSiZE
Hey man thanks alot...Ill prolly be buying one of the chrome 9port tanks soon. However with those front ports being so close is it easy to screw the 8 valve setups into those 4 ports?
ptman2002's avatar
ptman2002
i have 2 of those myself. you can see them in my profile.
kevin@aac
That is a firestone air tank. PN#9248
7" diameter, 34" long, 21.75" between the legs on center with 6 1/2" ports.
whynotfab's avatar
whynotfab
You'd probably have to assemble it a little different compared to one with spaced out ports, but it would work. I'd use something like Loctite 545 and take my time, just to be sure of no leaks and not have to take anything back apart.
95FullSiZE's avatar
95FullSiZE
Thanks for all the help guys, does anyone know about those "E" air tanks that suicidedoors was selling? I was thinking about getting one of those as well but no clue where to buy them SD has been SoldOut forever now.
s10
last post by baha +1y
