ok..i think ive got the air layout...now i need a "diagram"
CM
c mau
ok i think this is what im goin with....
(2)7 gallon air tanks..(FBIs Most wanted)
(1) Big unit air compressor..
(blackjack valves
1/2 inch line
so...how the hell do u hook all this up...im gonna pick up the F.B.S.S fitting set from F.b.I...thanks
CM
c mau
o im also running a pressure switch and solenoid ...sry..
and a 10 switch switchbox...
and that was 8 black jack valves...god damn smilies..lol
TacoFel's avatar
TacoFel
Better to run one tank and one compressor. 14gal to one compressor is too much for that POS. Get an Air Zenith.
CM
c mau
lol..i was told this compressor would fill 14 gallons in 11 minutes....whats the zenith doin??perhaps ill change up..
bdydrp18's avatar
bdydrp18
well it is hard to say. a lot of it is all up to how you want it to look. i would start by layout everything out where you want it and go from there
CM
c mau
no i knwow here i WANT everything..but this is my first air setup...what i wanna know is where to go with what lines and wires basically..
bdydrp18's avatar
bdydrp18
ok well is it a valve block or single valves.
but each bag needs a line, each valve will have a ground and power wire, ground the ground wire to the frame and the power wire goes to the switch boxes. each switch will control one valve and you can also wire them out to do f,b,s,s, and pancake.
bdydrp18's avatar
bdydrp18
here you go this well show you what to do
http://www.truckin.com/TRUCK-INSTRUCTIONS.html
bagginitdotcom
Regardless of what that guy from FBI said in your other thread, I would never run one compressor on 14 gallons unless it was an engine driven compressor or Oasis. 5 gallons is the max for about any viair compressor, 9 is the max for an AZ, and about that compressor that FBI has.... well... i'd search around first and see the horror stories that people have had when going to FBI for parts before I buy anything from them.
As for connecting it all up... you need airline and fittings for the air parts, and electrical connectors and wire for the electric stuff.
If you haven't already, go spend a few hours and read around http://www.bagginit.com
FAT NICK's avatar
FAT NICK
get a engine driven compressor all electric compressors #$%!in suck except oasis but all that is is a EDC with a big ass winch motor
Air Zenith arent all that people are makin em out to be
s10
last post by baha +1y
