Mazda Trucks
Genres:
All Genre's
Difference between b2200 and b2600
lowchick
Posted 1/26/2006 via Website
Edit Thread
Title:
Caption:
Ok, so i'm looking at an 87 b2600 for my husband but I noticed there are hardly any at all on here. Actually two. What is the difference between the two and why aren't people building them? Just not many made. Thought you guys might be able to help.
Nathan H
Edit Thread
Title:
Caption:
Edited: 1/26/2006 10:04:34 AM by KAOSS motor size and i think the 2600 has a different tranny,but i'm not sure though. b2000-2.0L, B2200-2.2L, B2600-2.6L. There are specific diffrences in how the 2.2 and 2.6 are set up with regards to the intake and exhaust.
Russ DingDong
Edit Thread
Title:
Caption:
the 87-88 b2600 was the same outwardly as the B2000/B2200, the main difference being the 2.6l 4 cyl from Mitsubishi. The frame is slightly different for the motor mounts and passenger side exhaust. Unfortunately they still use the same Nikki carb so the best upgrade for for performance is still a Weber 32/36 progressive, which will also get rid of that oily octopus on the drivers fender and the "canister vac" air cleaner. The 2.6 is both more powerful and more reliable than the 2.0/2.2 Mazda engine, and even more so than the later 89-93 B2600i which used a head cracking Mazda 2.6l engine. Good find, they are still good trucks, as long as it runs well without smoke you will have a Mazda truck that will keep up with traffic. They didnt make many in the 2 years they were available, and the higher cost means they frequently had more options, like trailer mirrors and two tone paint..
Javier Mayol
Edit Thread
Title:
Caption:
well there is a LOT of b-series mazdas on here. Now the b2600 is a dit different that a b200 or b2600. Normaly b2600 is a 4x4 with a 2.6 four cylinder engine and different powertrain all toghether including rear-end diameter and gears. They are very popular for their body lines. the hood has a pretty hump on it, the fenders are wider than regular. There might be a few things that I am missing. I am sure some one will point them out. If your husband is a member here more than likely he's going to want to lower it. If so a 4x4 is not the best option. I can be wrong but I don't think they make 2-wheel drive b-2600. If I am wrong someone please advice.
Mark Azarraga
Edit Thread
Title:
Caption:
Originally posted by MJAVY7 well there is a LOT of b-series mazdas on here. Now the b2600 is a dit different that a b200 or b2600. Normaly b2600 is a 4x4 with a 2.6 four cylinder engine and different powertrain all toghether including rear-end diameter and gears. They are very popular for their body lines. the hood has a pretty hump on it, the fenders are wider than regular. There might be a few things that I am missing. I am sure some one will point them out. If your husband is a member here more than likely he's going to want to lower it. If so a 4x4 is not the best option. I can be wrong but I don't think they make 2-wheel drive b-2600. If I am wrong someone please advice. not all b2600s are 4x4, the b2600s as far as i know did not come in 4x4, but on the other hand the b2600is came in 4x4 and some 2wd versions...differences between 2600 and 2600i has been mentioned above, one is carbed mitsu motor and one is fuel injection mazda
Brandon Blitch
Edit Thread
Title:
Caption:
and the 2600i was never offered in ex cab, but the reg 2600 was. i got a buddy though who has a 88 reg cab 2000 with a 93 2600i motor in it. he only wants 1500 for it..
Russ DingDong
Edit Thread
Title:
Caption:
Originally posted by low mazda and the 2600i was never offered in ex cab, but the reg 2600 was. i got a buddy though who has a 88 reg cab 2000 with a 93 2600i motor in it. he only wants 1500 for it.. no, they were both offered in ext cab, as 2wd. I have never seen a B2600 4x4 ext cab though. Doesnt mean there wasnt one, just that I havent seen one. And the bubble hoods only came on the 89-93 B2600i with the fuel injected motor. Never on the B2600. Didnt need it, the B2600 didnt have the intake going over the top of the engine.
Carlos Padilla
Edit Thread
Title:
Caption:
I have a 1991 B2600i Extended cab 2wheel drive so that helps with some of the confusion.
Russ DingDong
Edit Thread
Title:
Caption:
here is a B2600 4x4 ext cab, so it was just that I havent seen one. Big picture, so I'll link it.
Brandon Blitch
Edit Thread
Title:
Caption:
well i had a chance to buy a reg cab 87 mazda 2600. it had the mits engine in it was the only reason i decided not to buy it. but i know for sure it was legit, cuz it had the emblems and stickers under the hood still. and it was a reg cab b2600. carbed mits engine.
Russ DingDong
Edit Thread
Title:
Caption:
Originally posted by low mazda well i had a chance to buy a reg cab 87 mazda 2600. it had the mits engine in it was the only reason i decided not to buy it. but i know for sure it was legit, cuz it had the emblems and stickers under the hood still. and it was a reg cab b2600. carbed mits engine. who said they didnt make a 2wd 2600? They made them all, short bed, long bed, ext cab, 4x4 ext cab, 4x4 short bed, 4x4 long bed, all were made. If there was one that WASNT made as a B2600i, it would be the std cab long bed 4x4, that was only available with the mitsu motor.
Wayne Messbarger
Edit Thread
Title:
Caption:
Originally posted by MJAVY7 well there is a LOT of b-series mazdas on here. Now the b2600 is a dit different that a b200 or b2600. Normaly b2600 is a 4x4 with a 2.6 four cylinder engine and different powertrain all toghether including rear-end diameter and gears. They are very popular for their body lines. the hood has a pretty hump on it, the fenders are wider than regular. There might be a few things that I am missing. I am sure some one will point them out. If your husband is a member here more than likely he's going to want to lower it. If so a 4x4 is not the best option. I can be wrong but I don't think they make 2-wheel drive b-2600. If I am wrong someone please advice. and the wider fenders you speak of are 4x4 fenders, not specifically for a 2600 or 2600i, 4x4 fenders are the same for all the trucks in this series, same with the 2wd
Wayne Messbarger
Edit Thread
Title:
Caption:
to clarify that a little better, all the 4x4 fenders are the same, and all the 2wd drive fenders are the same, but the two are different
lowchick
Edit Thread
Title:
Caption:
So I went and checked it out and it is an 87 and the body it has a few very small dings but nothing major. It has original paint, 2wd, runs good, dash is in great shape, 110,000 miles, new head, low compression pistons, rod bearing, timing chain, tensioners, and guide, plug, plug wires, and distributor cap, improved fuel pump and filter, water pump, radiator flushed, heater control valve, transmission shift valve, exhaust system, thermostat, and tires. It does have a crack in the windshield so I talked him down to $1600. Also the body has not an ounce of rust. Is this a good buy or should I look elsewhere?
Brandon Blitch
Edit Thread
Title:
Caption:
i'd buy it, with all that shit being new, it's a steal...
Russ DingDong
Edit Thread
Title:
Caption:
Originally posted by low mazda i'd buy it, with all that shit being new, it's a steal... 2nd'd
Javier Mayol
Edit Thread
Title:
Caption:
Edited: 1/26/2006 1:44:32 PM by MJAVY7 Originally posted by lowchick So I went and checked it out and it is an 87 and the body it has a few very small dings but nothing major. It has original paint, 2wd, runs good, dash is in great shape, 110,000 miles, new head, low compression pistons, rod bearing, timing chain, tensioners, and guide, plug, plug wires, and distributor cap, improved fuel pump and filter, water pump, radiator flushed, heater control valve, transmission shift valve, exhaust system, thermostat, and tires. It does have a crack in the windshield so I talked him down to $1600. Also the body has not an ounce of rust. Is this a good buy or should I look elsewhere? wow that sounds great (in florida anyways). Just the engine has that much money. Thanks to everyone that helped to clarify my previous post. I actually learned something today.
lowchick
Edit Thread
Title:
Caption:
Alright, looks like i'm picking it up on saturday. Last question that i'm sure russ or someone will be able to answer is, do other parts fit with the b2600? Like can i get a 4x4 b2200 bed, hood, etc. for it? Thanks so much for the help guys.
andrew kimbrell
Edit Thread
Title:
Caption:
All the body parts should be interchangeable. Only mechanical or motor parts would be model specific. Suspension parts should be the sam, or very similar and possibly adaptable.
Russ DingDong
Edit Thread
Title:
Caption:
Originally posted by crux131 All the body parts should be interchangeable. Only mechanical or motor parts would be model specific. Suspension parts should be the sam, or very similar and possibly adaptable. you are right! Suspension, body, interior, all the same. The difference is in the drivetrain, although the rearends will interchange.
lowchick
Edit Thread
Title:
Caption:
Thanks for the help. You all have been a big help to me and I really appreciate it.
style="width:500px">
Close
Close
